Identifying CMOS ICs
Postby geekyworld » Fri Jan 23, 2015 11:05 am
I have a few old IC 555s lying in my component box. How to find if the ICs are CMOS or not?
Thanks.
geekyworld
Re: Identifying CMOS ICs
Postby pebe » Fri Jan 23, 2015 11:43 am
If the part number has a 'C' in it, such as LMC555, then it is almost certainly CMOS
Postby KMoffett » Mon Jan 26, 2015 2:50 pm
Also the TS555, TLC555, ICM7555, ALD555, CS555C are CMOS....Maybe others that have come and gone too.
What part #'s?
$169.75
Southwire 28828255 250 ft. 12/2 Solid Romex SIMpull CU NM-B W/G Conductor Cable pictureCommon Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned
$230.30
Common Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned pictureCommon Sense Marine 18 Gauge 2 Conductor Marine Wire 75 ft 18/2 AWG
$61.24
Common Sense Marine 18 Gauge 2 Conductor Marine Wire 75 ft 18/2 AWG pictureSchneider Electric 19091 Distribution Terminal Block NG125 New NFP (4pcs)
$280.85
