Motor triggered by a vibration sensor
Re: Motor triggered by a vibration sensor
Postby pebe » Tue Jul 02, 2013 7:25 pm
Your 12V 1A motor will probably take up to 5A when starting up from rest. The contacts of the Panasonic NF2EB are only rated at 2A. They may be adequate but this Omron G2RL-2-12DC is rated at 8A, so would be a better one.
Postby julienfhd » Thu Jul 04, 2013 7:31 am
One more Thing, what's the purpose of the 1N4148?
julienfhd
Postby pebe » Thu Jul 04, 2013 9:42 am
When the relay is on and then is suddenly switched off, the energy stored in its inductance generates a high voltage in the reverse direction. So the end of the winding connected to the collector tries to go highly positive.
Without the diode the voltage would be high enough to damage the transistor. But the diode conducts, absorbing the power, and limits the collector voltage to about +12.8V
Postby julienfhd » Wed Jul 10, 2013 7:31 pm
The project was a success, thank you very much...
I did some modification though, like adding an inverter to successfully include the sensor to the circuit; and the motor I used had its polarity controlled by a third wire, so I did some tweaking to the relay's output, but I couldn't have done it without you.
Really Pebe, you were a lifesaver :)
julienfhd
Postby pebe » Thu Jul 11, 2013 12:28 pm
I'm pleased it all went well for you. :)
Previous
SOLA MCR Constant Voltage Power Conditioner 63-23-230-8 3000VA 60Hz
$1000.00
SOLA MCR Constant Voltage Power Conditioner 63-23-230-8 3000VA 60Hz pictureAutomated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller
Automated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 pictureMacurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller
$500.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller picture
