Linear Actuator to Reverse when power is off
Re: Linear Actuator to Reverse when power is off
Postby pebe » Sun Aug 18, 2013 9:26 am
Battery power is always applied to the actuator via contacts 5 and 6, whether the light switch is on or off.
So if one of the limit switches is intermittent it must be replaced, otherwise there is a risk of the actuator 'frying'.
Previous
$27.04
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$365.99
1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves pictureDC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B picture
