Opening a door on a timer
Postby Juel » Thu May 05, 2011 1:35 pm
Can any one help with making a circuit using a solar panel, windscreen wiper motor and a timer. I'm am keeping chickens and would like to setup a system to open and close a small door on my chickens coop at programmable timer?
This would have to be dc as it needs to be moved around.
Thank you very much.
Jason
Juel
Postby phillid » Thu May 12, 2011 8:04 am
I would recommend using a PICAXE programmable chip and a time chip suited to it.
phillid
Circuits
Postby jamesjohn » Sat Jun 04, 2011 6:18 pm
You have to be a genius to be doing that ....tell us how it progressed.
jamesjohn
$27.04
US Stock 154LB 70kg Lifting Magnet Electromagnet Solenoid Lift Holding 59mm 12V picture 3-in-1 EMF Meter, 5Hz-6GHz, Handheld Rechargeable Electromagnetic Field Radiati
$142.54
 3-in-1 EMF Meter, 5Hz-6GHz, Handheld Rechargeable Electromagnetic Field Radiati picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$375.99
1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves pictureDC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B picture
