HELP....BASICS OF TRANSISTORS(Any help will be appreciated!)
Postby anuragsm » Mon Jun 27, 2011 3:33 am
I understood the transistor action(emitter-base voltage acts like a gate and allows more electrons to diffuse into the collector region and the voltage applied to collector acts like a suction to [disallowed word] all the electrons) but now when we have different configurations such as "Common" Emitter and "Common" Base,
1) I don't understand what is the difference between the two!!!
2) In both the cases the base-emitter region is forward biased and collector base reion is reverse biased. So what is the difference between the two??
3) How does the common terminal control the current between the other two regions?
4) What do you mean by grounding? Please help me visualize!!!!
PLEASE HELP!!!!!!!!!!!!!!!!!!!!!
anuragsm
Postby pebe » Mon Jun 27, 2011 6:09 am
Try this link. The site is a mine of information.
http://www.allaboutcircuits.com/
Postby anuragsm » Mon Jun 27, 2011 10:29 am
naah...didn't help...basically i want to understand what the common terminal does and how it "controls" the current with some sort of example and how each configuration is different....i already have understood how the transistor functions...
anuragsm
Postby pebe » Mon Jun 27, 2011 12:34 pm
You should have read on!
http://www.allaboutcircuits.com/vol_3/index.html
Chapter 4 deals with every confiuration of bipolar transistors - common base, common emitter, common collector and cascode.
What more do you want?
$169.75
$500.00
Cooner Wire NMUF 2/30-4046SJ Ultra-Flexible Micro PVC Cable, Gray, 2C, 250 ft. pictureCommon Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned
$230.30
Common Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned picture1000Ft UL 8 Conductor Silver Satin Modular Cable Reel 26AWG
$337.04
1000Ft UL 8 Conductor Silver Satin Modular Cable Reel 26AWG picture
