Need advise for a project
Postby Bmarquardt » Thu Jul 28, 2011 2:11 am
I need advise on how to solve what I believe is a simple problem.
The sole purpose of the design is to monitor a lead which will be used for a security application. I need a way to monitor that the lead is still intact, and if disconnected, or cut, I need a switch to close passing a small amount of current thru a second system.
Bmarquardt
relay
Postby bitsandpieces » Sat Sep 03, 2011 12:03 am
a dual pole relay would do the trick.It has 2 outputs,1 is on when the primary is on and one is off.When the primary switches off the poles are reversed
bitsandpieces
$57.99
Adjustable DC 0-30V/60/120V 0-3/5/10A Lab Power Supply Variable Bench Switching pictureSorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply
$250.00
Sorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply pictureEMERSON SOLA SDP 5-5-100T POWER SUPPLY
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY pictureSilent Knight 5495 Power Supply SK-5495 Replacement Board - Used
$329.00
Silent Knight 5495 Power Supply SK-5495 Replacement Board - Used picture
