Need Help - Using 8051 with RS232
Postby maxfourier » Sun Aug 07, 2011 4:36 am
I'm an electronics student working on my first project. I have explained my problem below. Need some help.
Please consider that I'm a newbie with projects.. I have only brought a few things and downloaded some software. Apart from that I have my logic ready. So, all i would need to do is write the code and program the microcontroller.
[b]This is what i have :[/b]
[b][COLOR="darkred"]Hardware :[/COLOR][/b]
8051 (NXP 80V51RD2)
RS232 with DB9
max232
[b][COLOR="darkred"]Software :[/COLOR][/b]
Keil
Flash Magic
[b][COLOR="black"]What i want to do : [/COLOR][/b] is just program the microprocessor. I have tried Googling "Interfacing 8051 rs232" but could not really get it.
I can interface the microprocessor and the max232 but I'm having problems interfacing the RS232.
Moreover, I have NO idea how (& where) to connect the RS232. Here is what my cable looks like :
[img]https://lh6.googleusercontent.com/-yozSGJzf1_0/Tj4U141IcLI/AAAAAAAAASc/BzCSmazqVSs/s800/project.jpg[/img]
[b][COLOR="darkslategray"]
Again, What i need to know is:[/COLOR][/b]
-Which side of the cable goes where(PC n 8051)
-How is it connected to the microprocessor.
-How do I write my c code into the microprocessor - How to convert it to hex(or whatever required)? Why do I need Keil & Flash Magic?
maxfourier
$7.77
$400.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 pictureAutomated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller
Automated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller picture
