Coffee Urn Heater too low
Postby mrpat » Wed Sep 21, 2011 2:54 pm
I have a 30 cup urn that brews coffee well. The problem is that when it is done brewing it keeps the coffee at approximately 145 degrees F. I would like to make it keep at around the 190F mark. Replace thermistor perhaps?
mrpat
Postby mrpat » Mon Sep 26, 2011 4:33 pm
http://www.google.com/products/catalog? ... CDoQ8wIwAA
Do you think I could replace the existing thermostat with this one? It connects the same way.
Thanks for the help in advance,
Pat
mrpat
Postby pebe » Mon Sep 26, 2011 7:39 pm
That is a dryer thermostat for measuring air temperature. I should not think it would be much good for measuring water temperature
$25.00
$88.88
$180.00
$300.00
