Logic gates / counter help/ :(
Postby wiztaylor » Wed Oct 26, 2011 10:04 am
Logic gates / counter help/ :{
Hey guys,
I Really hope you could help / advice me with my project.
My project is to create a car that will pass thru 9 stations overhead bridges. The car has a LDR on the top. The car will start at
station 1 and pass thru till station 9. When the car passes thru each station, it will count up till 9 (getting trigger signal from
the LDR). Once it reaches station 9, it will send a signal to the motor driver circuit (See picture (Pin J8 connected to a relay))
which will cause the car to reverse and it will need to countdown as goes back to station 1.
I have the following circuit’s boards:
LDR Circuit
http://farm7.static.flickr.com/6229/627 ... 4f15be.jpg
Motor Driver & Power supply (9V to 5V)
http://farm7.static.flickr.com/6112/627 ... fa1b_b.jpg
UP/DOWN Counter (74LS193) to BCD (74LS47) to 7 Seg display
http://farm7.static.flickr.com/6232/627 ... 0d39_b.jpg
Here is the overview picture of the whole circuit:
http://farm7.static.flickr.com/6114/627 ... a90b_b.jpg
[u]The above circuits have been given, i will need to design a "c0unting limiting circuit" which will act as the brain of the car.[/u]
The components I can use are:
74LS32 OR gate
74LS08 AND gate
74LS04 NOT gate
74LS02 NOR gate
74LS00 NAND gate
74LS74 D flip flop
2N3904 NPN transistor
I hope and appreciate you are able to help as i really lost. Thanks alot!!!
wiztaylor
Postby Thomas W » Thu Oct 27, 2011 5:23 pm
Your car can be in 18 different states:
1. Heading for bridge 1, driving forward.
9. Heading for bridge 9, driving forward.
10. Heading for bridge 9, driving in reverse.
18. Heading for bridge 1, driving in reverse.
You'll need a 6 bit memory to be able to represent 18 different states.
1 flip flop is 1 bit.
Draw a state diagram: [url]http://en.wikipedia.org/wiki/State_diagram[/url]
An output from the Count Limiting Circuit should be connected to J8 pin 3.
Thomas W
​Nordic Semiconductor Power Profiler Kit II nRF-PPK2 Current Measurement Tool
$79.99
​Nordic Semiconductor Power Profiler Kit II nRF-PPK2 Current Measurement Tool pictureDCA55 Version Semiconductor Tester, Compatible with DCA55 Semiconductor Analyzer
$88.88
$180.00
$300.00
