PCB identification
PCB identification
Postby sherbie » Thu Nov 17, 2011 1:33 pm
Hi all, this is a bit of a long shot, but does anyone have any idea what this PCB might be for?
I have a few of them, packed in padded boxes and sealed. The NIN suggests it's a circuit board for some sort of military equipment, but other than that I don't have a clue. Not sure if it will have some sort of value to the right person, or if it all just wants sending for scrap.
I presume the shiny metal surface is just some cheap tin/solder covering? Really appreciate any help, and if you don't know what it is but know someone who might be able to tell me, I'd be really grateful if you could give me a shove in the right direction!
sherbie
Re: PCB identification
Postby Thomas W » Mon Nov 28, 2011 1:40 pm
I believe the surface is covered with solder, yes.
What does NIN stand for?
From Wikipedia:
"EDO (UK) Ltd includes EDO MBM Technology Ltd in Brighton UK, and designs, develops and manufactures weapon interfacing (carriage and release) systems, cable assemblies and electrodynamic products for the aerospace and defense industries. The UK firm makes the EDO MBM Zero Retention Force Arming Unit."
Thomas W
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style pictureRectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 pictureZP500A/300A/50A/30A 1600V Power Stud Rectifier Diode Negative Reverse/ Heat Sink
$26.97
ZP500A/300A/50A/30A 1600V Power Stud Rectifier Diode Negative Reverse/ Heat Sink picture
