Newbie question: Passive Delay Circuits
Postby SparkyNZ » Thu Dec 01, 2011 7:55 am
Hi, I'm somewhat inexperienced in electronics (I've soldered wires, cables, made a few circuits with 555 timers etc). I have an old vintage computer that I've just rewired to with with S-video.
The problem I have is that the luminance and chromaticity signals are slightly out of phase which results in a little ghosting on my monitor.
Could somebody please recommend a way in which I could build a circuit that would introduce a delay of around 150 nanoseconds on the signal? I'd want to be able to try adjust the delay slightly too.
I've been recommended a TZB78-7 IC form Rhombus but quite simply because I only would want one chip, they're not interested in me making an order.. so I'm wondering if there's a low cost way of building such a circuit from good old-fashioned everyday components?
Paul
SparkyNZ
Re: Newbie question: Passive Delay Circuits
Postby Thomas W » Sun Dec 04, 2011 10:31 am
Rhombus explains:
[url]http://www.rhombus-ind.com/dlcat/app1_pas.pdf[/url]
Thomas W
$19.73
$550.00
$169.99
$499.99
