Newbie Part question
Postby chazkayak » Wed Dec 28, 2011 7:23 pm
Hi all, this is my first dabble into the world of electronics since building a LED circuitboard back in 1982!!!
Here goes
My PC monitor stopped working a while back, recently i decided to have a go and fix it. I took the back off and looked at power in first of all.
I found a small fuse shaped like a resistor next the the power in plug. I ran a voltmeter accross it to check for continuity in both directions and got no reading either direction.
The part is as small as a resistor in clear glass with a fuse wire element, which looks broken, there is a red marking inside the glass but no other marking.
Can anyone help with identifying this part and point me in the direction where I can get a new one?
Many thanks
chazkayak
Re: Newbie Part question
Postby pebe » Tue Jan 03, 2012 5:05 am
If it is about 20mm long and near the power input, then it is almost certainly a fuse.
First confirm that there is continuity between each side of the fuse and one or other of the mains input wires. If so then try replacing it with a 2A 250V fuse.
MSA ALTAIR 4XR Gas Detector Monitor - ALTAIR 4XR
MSA ALTAIR 4XR Gas Detector Monitor - ALTAIR 4XR pictureMSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026
$600.00
MSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026 pictureMSA Galaxy GX2 Automated Test System, Cylinder Holder, Altair/Altair Pro, 5/5x
$750.00
MSA Galaxy GX2 Automated Test System, Cylinder Holder, Altair/Altair Pro, 5/5x pictureMultigas MSA Altair 4X GAS Monitor detector Calibrated / NO Charger
Multigas MSA Altair 4X GAS Monitor detector  Calibrated / NO Charger picture
