Using ground as a reference point for measuring voltages
Postby webplodder » Fri May 11, 2012 11:09 am
Hello. I have been reading about using some arbitrary point as ground in a circuit in order to measure voltages with respect to it but am still perplexed because the text I am reading does not seem to make clear why this is useful in electronics. Any help appreciated. Thank you.
webplodder
Re: Using ground as a reference point for measuring voltages
Postby electric_guide » Sun May 27, 2012 1:23 pm
Ground is only a connection point between all relevant components in the electronic circuit in order to make one reference point.
it is not really connected to the ground.
for example a battery with DC voltage (+ and -) connected to a voltage divider with resistors.
in order to measure the voltage on one resistor related to the battery you need to define a reference point.
you call the (-) tap of the battery a "ground" and measure all voltages related to this point (the + tap of the voltmeter connected to the measure point and the - tap connected to "ground" point)
another simple example is connecting to boards (to circuits together).
you must connect them with a reference point . you take the ground point of each circuit and connect them together.
electric_guide
$62.99
Adjustable DC 0-30V/60/120V 0-3/5/10A Lab Power Supply Variable Bench Switching pictureSorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply
$250.00
Sorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply pictureEMERSON SOLA SDP 5-5-100T POWER SUPPLY
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY pictureSilent Knight 5495 Power Supply SK-5495 Replacement Board - Used
$329.00
Silent Knight 5495 Power Supply SK-5495 Replacement Board - Used picture
