Beginner Newbie
Beginner Newbie
Postby montyloree » Sat Jul 28, 2012 2:57 pm
I'm learning electronics so that I can built DIY solar panels...
I've bought a few books... electronics for dummies etc and have been reading them...
I bought a breadboard with some LEDs and resistors and a 12v battery...
Am I able to ask some very basic newbie questions here...
and.. can i post some photos of the breadboard so that i can understand what's going on?
The concept of DIY solar panels is great.. however, for a person who's never dealt with electronics, it seems a bit overwhelming
montyloree
Re: Beginner Newbie
Postby kbs » Sun Oct 14, 2012 5:32 pm
If you have a small output solar panel feeding a large lead acid battery then this is very simple.
Could you indicate the expected power from the solar panel, the intended battery capacity and the level of voltage regulation required?
Kb
kbs
Re: Beginner Newbie
Postby ataripunkconsole » Thu Oct 18, 2012 12:20 am
Breadboards are great I love them and them make testing out circuits soo much easier. The way it works is along the bottom and top you have 2 horzontal rows of holes. The are usually configured as positive and negative power. All the holes in one horizontal row are connected by a copper piece. Then the holes in the middle go in vertical rows. Each row is also connected by a separate row of copper. Hope that helps explain the breadboard.
ataripunkconsole
Honeywell AC Solenoid Valve 50041883-002 for HE100 and HE200
$22.45
Honeywell AC Solenoid Valve 50041883-002 for HE100 and HE200 pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW pictureNITRA AVS-5312-24D Pneumatic Solenoid Valve 5-Way/2-Position 24V DC
$80.00
NITRA AVS-5312-24D Pneumatic Solenoid Valve 5-Way/2-Position 24V DC picture
