Simple Dead Man's Handle/Button Curcuit
Postby GAFAAAAA » Fri Aug 10, 2012 11:04 am
I'm a bit of a newbie to this kind of circuitry, I just wondered if someone could give me some kind of idea as how to make a circuit where [b]after 5 or so minutes an LED comes on and if a button is not pressed within 30 seconds a buzzer sounds[/b] like some sort of dead man's handle. I will need quite a bit of help, I understand it will probably incorporate a 555 or 556 chip for timing, but other than that, I don't really know what i'm doing.
Any help at all would be great
Gareth
GAFAAAAA
Re: Simple Dead Man's Handle/Button Curcuit
Postby kbs » Sun Oct 14, 2012 5:28 pm
Are you still looking for help on this?
If so, do you need to do it with external timer chips (available as project/demo boards if you don't want to make your own circuits) or could you use the old fasioned octal relays with timer bases? (more expensive but easily configurable).
Kb
kbs
Johnson Controls Metasys AS-UNT111-1 Unitary Controller - UNT 111-1
$35.00
Johnson Controls Metasys AS-UNT111-1 Unitary Controller - UNT 111-1 pictureJohnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B
$35.99
Johnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B pictureJohnson Controls Metasys Controller CVM03050 Module Board
$138.75
Johnson Controls Metasys Controller CVM03050 Module Board pictureMetasys N30 Supervisory Controller Base Unit N2 Field Bus Ethernet MS-N301310-1
$320.00
Metasys N30 Supervisory Controller Base Unit N2 Field Bus Ethernet MS-N301310-1 picture
