circuit simulation software
Postby Anthony2012 » Sat Dec 08, 2012 6:03 pm
What software would you recommend for simulating circuits?
Ideally free but I don't mind paying a bit for something worthwhile.
Anthony2012
Re: circuit simulation software
Postby pebe » Sun Dec 09, 2012 2:30 pm
I rarely use one, but when I do it's LTspice from Linear Technology.
It's free.
Postby Anthony2012 » Sun Dec 09, 2012 2:51 pm
thanks for that. I found Yenka last night and I have been giving that a go.
I am managing to break components with reckless abandon but I am making some progress. I will continue with Yenka and then give LTspice a try later.
I hope to have something to add to my other post in a day or so.
Anthony2012
$27.04
$13.63
$375.99
1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves pictureSDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture
