First Project - Multi-Charger
Postby herghost » Sun Jan 06, 2013 1:58 am
Hi Guys and Girls
I have decided to build a multiple usb charger for the gadgets I have around, a nexus 7, galaxy s3 and an original kindle.
Basically I plan to build a platform out of foam and have the devices charge from a powered usb hub.
What I would really like to do is have some kind of led illumination to show the charge status of each device.
This is where I am stuck! Is there a way of getting the charge status from a usb cord? I have a battery charger that has an led which changes colour when a battery is charged which I have taken apart to have a look, this also includes an usb output for charging, however the indicator only works when a battery is used with the charger, not from the usb port.
All the devices charge from mini-usb.
Does anyone know if this is possible?
Many Thanks
Dave
herghost
$37.00
Raspberry Pi Compute Module 4 CM4 2GB RAM + Carrier Board pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureRAM Jack 10 Ton Capacity 10" Stroke Hydraulic Piston Frame Machines & towers
$274.99
RAM Jack 10 Ton Capacity 10Allen-Bradley 1775-ME8 Memory Module
$984.62
Allen-Bradley 1775-ME8 Memory Module picture
