Need to confirm equation for this circuit
Postby AARRGGHHH » Wed Feb 20, 2013 8:04 pm
This circuit is named ((AB)' + (CD)'). However, isn't the correct equation ((AB)' + (CD)')[b]'[/b] ? Comments are invited, I'd like to get a consensus on this.
Thank you
((AB)'+(CD)') GATE.PNG (2.67 KiB) Viewed 9273 times
AARRGGHHH
Re: Need to confirm equation for this circuit
Postby JoshMac » Mon Apr 15, 2013 3:27 pm
Hi AARRGGHHH,
I believe [code] ((AB)' + (CD)')' [/code] is the correct equation for this.
Enjoy your logic fundamentals :)
Josh
JoshMac
Postby Corrupteddrake » Mon Jul 15, 2013 10:12 pm
Oops, think you are right.
It looks like ((AB)' + (CD)')' to me.
[url=http://www.jansen-team.com/][img]http://s3-ec.buzzfed.com/static/enhanced/web04/2012/1/20/14/anigif_enhanced-buzz-21524-1327086500-29.gif[/img][/url]
Corrupteddrake
$17.92
$40.50
$225.00
$11.06
