Bottleneck 555's 0.2A Stuck project
Postby 121434244 » Thu Apr 25, 2013 3:22 pm
Hello
I made this: (555 pwm, but it has a bottleneck because I can't use higher load than 0.2A)
[url]http://www.easterngeek.com/2008/06/simple-and-dirty-pulse-width-modulation.html[/url]
How to easily mod it to accept more current ?
1.) list what components to add.
2.) a drawing how and where to solder these extra components.
I hope it could handle:
Voltage input: U=6-12V (I use different battery packs)
Current draw: I=10A (max.could be less for geared motor 12V)
Suggestions
and easy to understand guides so I can solder the "add-ons" myself.
121434244
Re: Bottleneck 555's 0.2A Stuck project
Postby dvhenry » Thu Jul 25, 2013 11:47 am
[url]http://home.cogeco.ca/~rpaisley4/LM555.html#32[/url]
dvhenry
$7.77
$400.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller pictureAutomated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller
Automated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 picture
