simple gsm project
simple gsm project
Postby uydarp » Sun Apr 28, 2013 10:16 pm
i wish to control a servo motor using a cellphone.
How it should work.
1. A call from a know phone number calls a sim900 circuit.
2. Microcontoller check if the call is from a know phone number, if yes call is answered and a password is expected, DTMF decoder is used to check the password
3. If the password is correct the servo motor turns 180 degrees n back to 0
degrees, finish!
i have made a working model using arduion UNO & icomsat gsm shield,
now i want to build the same circuit by manually connecting all the components instead of arduino n shield on a breadboard
How should i go about doing it? what all components will i need?
thanks in advance!
uydarp
$37.00
Raspberry Pi Compute Module 4 CM4 2GB RAM + Carrier Board pictureFor Dodge Ram 1500 09-18 5.7L Performance Long Tube Stainless Headers NEW
$236.59
For Dodge Ram 1500 09-18 5.7L Performance Long Tube Stainless Headers NEW pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureRevolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC
$449.95
Revolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC picture
