egg project
egg project
Postby dakosvetnik » Fri May 03, 2013 5:20 am
Hi everyone! :)
I just discovered this forum googling help for newbies. And I'm so glad I found it.
I'm trying to get some hands on experience in electronics, and this seams to be the right place for that. :)
I'm currently working on the egg project.
This is my first project ever so I was thinking of making something simple.
Unfortunately, I got stuck.
Idea was to make something like this:
[url]http://i39.tinypic.com/152ccgk.jpg[/url]
one egg glows if you turn on the switch,
and the other glows if you move it close to the first glowing egg.
I figured out the principle behind it.
I have a coil in each egg and use inductive coupling to transfer energy to the 2nd egg.
According to wikipedia this can be easily done by making two LC circuits resonate.
but I have no idea hot to do it in practice.
[url]http://i44.tinypic.com/2u94rk5.jpg[/url]
Is this ok for the second egg? I'm not certain I can just connect LED like that?
And I don't even know how to start on the first one. Do I need some kind of oscillator for it, aside from the battery and switch?
What should I keep in mind to avoid explosion? :mrgreen:
hope you have some advises. :)
dakosvetnik
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 pictureZP500A/300A/50A/30A 1600V Power Stud Rectifier Diode Negative Reverse/ Heat Sink
$26.97
ZP500A/300A/50A/30A 1600V Power Stud Rectifier Diode Negative Reverse/ Heat Sink picture
