how to send data through a dc line connected to led
Postby electroyas » Mon Jul 01, 2013 12:11 pm
how can i send data signals to units to on led only with two wire power lines dc. Led can not be blinked becaused of this...
Life is a great mystery
electroyas
Re: how to send data through a dc line connected to led
Postby pebe » Mon Jul 01, 2013 2:58 pm
Your question is too vague to reply to. What sort of data? What units?
"Led can not be blinked becaused of this.." ---because of what? Why ?
Postby electroyas » Mon Jul 01, 2013 5:02 pm
actually i'm trying to automate my home lighting system with central microcontroller, in order to on off each led lights unit i need to send data throught the dc 12 v power lines without any control wires. Is it possible?
electroyas
Postby pebe » Mon Jul 01, 2013 6:12 pm
It would be possible - but not easy. The source and load of your 12V lines would have a low impedance and trying to force data on to them would require a lot of power.
You could put the data on to a carrier but that would entail fitting filters in your system to inject the data and retrieve it. Unless you know what you are doing in that field then the simple answer is that it's not possible.
Postby electroyas » Mon Jul 01, 2013 6:15 pm
thanks for the quick reply. It seems that i may have to have a seperate wire for that.
electroyas
$139.00
Shark Stratos Cordless Vacuum, Clean Sense IQ & DuoClean PowerFins (Refurbished) pictureProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip
ProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip pictureIdex / Systec Vacuum Pump 9000-1926 bench tested and GUARANTEED to work.
$245.00
Idex / Systec Vacuum Pump 9000-1926 bench tested and GUARANTEED to work. pictureCordless Vacuum for DeWalt 20V Battery,5 in 1 Handheld Electric Vacuum Cleaner
$54.90
Cordless Vacuum for DeWalt 20V Battery,5 in 1 Handheld Electric Vacuum Cleaner picture
