Newbie SMD confusion ????
Postby Happy_Jock » Mon Oct 21, 2013 1:17 pm
Hi folks
I have a few small Fm transmitter circuits I am keen to build in Surface mount to reduce the size. I have read a little into SMD and understand there are different sizes etc.
Silly as it may sound I am very confused if when building a schematic using Surface mount, are the exact same value of SMD components used which are described in the TH schematic, OR is it necessary to change the value of certain components when using SMD in a circuit.
or put another way if I wanted to build a TH schematic in Surface mount, do I just use the same value of surface mount, or is their some kind of value or performance difference due to size?
any help would be much appreciated and unblock this awkward blob on my road to advancing to smd
cheers
Happy_Jock
Re: Newbie SMD confusion ????
Postby pebe » Fri Oct 25, 2013 9:21 am
What's a 'TH' schematic?
Postby colin55 » Sun Oct 27, 2013 8:09 am
See Talking Electronics Voyager MkII for a surface-mount FM transmitter
Colin Mitchell
Talking Electronics.com
[email protected]
colin55
SMC VZ2150 solenoid valve
$10.00
SMC VZ2150 solenoid valve pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureParker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA
$174.99
Parker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA pictureOEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid
$75.00
OEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid picture
