Voltage Detector with numeric and led display
Postby mihai93 » Thu Oct 24, 2013 7:07 pm
I have two voltages I'm measured on input power and output power of a 4 pin connector. I wish to display voltage, which varies from 0-28v, and I want respective leds to light up when there is any voltage > 0v present.
I'm thinking to use this display: http://dx.com/p/3-digit-red-led-display ... 30v-149570
My primary concern is how to set up a LED to turn on when ANY voltage is present without interfering with the display voltage.
Thanks in advance!
mihai93
Re: Voltage Detector with numeric and led display
Postby pebe » Mon Nov 11, 2013 12:36 pm
The spec for the meter states a measuring range of 4.5V to 30V. So what happens when you try to measure 4.0V? Or do they mean a supply voltage range of 4.5V to 30V?
What is the minimum voltage you mean when you say 'any' voltage?
Siemens Q2100P 100 Amp 2 Pole Type Circuit Breakers
$37.95
Siemens Q2100P 100 Amp 2 Pole Type Circuit Breakers  pictureSiemens Simovert Masterdrive 6SE7015-0EP50-Z USED
$888.33
Siemens Simovert Masterdrive   6SE7015-0EP50-Z USED pictureSiemens Simodrive LT-Modul 6SN1124-1AB00-0AA1
$275.00
Siemens Simodrive LT-Modul 6SN1124-1AB00-0AA1 pictureSiemens 6ES7212-1AG50-0XB0 PLC CPU Module 6ES72121AG500XB0 New DHL Shipping
$168.54
Siemens 6ES7212-1AG50-0XB0 PLC CPU Module 6ES72121AG500XB0 New DHL Shipping picture
