Flash and sound circuit
Postby Drknght » Sun Dec 22, 2013 2:26 am
I would like to build a circuit that will give a single flash (single discharge of a strobe bulb/capacitor) and a sound effect.
Ideally the sound effect would be customizable. And the whole thing would run off say six AA batteries (or whatever).
Thanks in advance for the help.
Drknght
$27.04
$85.00
$13.63
$375.99
