1N4148 Diode circuit
Postby JasonMcG » Sun Mar 02, 2014 6:02 pm
Design and draw the appropriate circuit to be used in measuring the diode forward current I, using a 5V dc source to forward bias a 1N4148 diode, a 10k ohm potentiometer to vary the dc voltage and a 330 ohm resistor to limit the current through the diode.
Is this the correct circuit? If not, what is the correct circuit?
http://i1362.photobucket.com/albums/r68 ... 8df1b0.png
JasonMcG
Re: 1N4148 Diode circuit
Postby pebe » Mon Mar 03, 2014 10:27 am
As drawn, the voltage applied to the LH side of R1 is fixed. Make it variable by taking R1 to the wiper of the pot instead of to battery+
Postby JasonMcG » Mon Mar 03, 2014 1:41 pm
How do you draw this?
JasonMcG
Postby pebe » Mon Mar 03, 2014 5:19 pm
[quote="JasonMcG"]How do you draw this?[/quote]
I don't understand.
Postby JasonMcG » Mon Mar 03, 2014 5:58 pm
JasonMcG
Postby pebe » Mon Mar 03, 2014 6:43 pm
Yes, thats correct.
Postby JasonMcG » Mon Mar 03, 2014 8:04 pm
JasonMcG
$20.50
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring pictureDental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA
$145.00
Dental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA pictureScintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM
$49.00
Scintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM pictureBorescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera
$29.99
Borescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera picture
