need help
need help
Postby Sherlock » Tue Sep 16, 2014 9:00 am
I want to know what happens when we lift a pin of an IC from PCB
Sherlock
Re: need help
Postby pebe » Tue Sep 16, 2014 10:50 am
Your question is too vague. Can you be more specific?
Re: need help
Postby Sherlock » Tue Sep 16, 2014 11:20 am
i have lifted output pin of an LDO IC, I want to know what will happen to the circuits which are driven by the output of the LDO IC
Sherlock
Re: need help
Postby Sherlock » Tue Sep 16, 2014 11:38 am
I have a LDO 5V tracker, it was giving me 2.6V output instead of 5V.
But when i lifted the outpin pin of the same LDO and checked the voltage at the PCB track, it was 5V
Sherlock
Re: need help
Postby pebe » Tue Sep 16, 2014 12:33 pm
You have still not provided enough information to work on.
Did the circuit develop a fault? If so, what were the symptoms? What is the make and type of the LDO? What other measurements have you made? How is the tracking voltage set? Can you give the circuit details?
Without more detail, you might just as well ask how long is a piece of string!
$14.98
6Pack K Type Mini-Connector Thermocouple Temperature Probe Sensor Cable pictureThermometer Lot - Thermapen One Blue Probe - Cooper Waterproof Digital DFP450W
$69.99
Thermometer Lot - Thermapen One Blue Probe - Cooper Waterproof Digital DFP450W pictureThermocouple Thermometer Temperature Data Logger 4-Channel K/J/T Type Thermomete
$109.71
Thermocouple Thermometer Temperature Data Logger 4-Channel K/J/T Type Thermomete pictureDigital Thermocouple Thermometer K Type Temperature Meter (-50 to 1300 °C)
$26.42
Digital Thermocouple Thermometer K Type Temperature Meter (-50 to 1300 °C) picture
