What component makes a stroboscope flash?
Postby radiator » Mon Nov 24, 2014 4:07 pm
Hello
Does anyone know what makes a stroboscope flash? I have a light mixer, and it has a strobe button. When you press and hold the button the strobe starts to flash repeatedly, but now when you press the button it just flashes once. I opened the mixer, checked the components, and I don’t know what could be wrong. There is a 14 pin semiconductor (tc4584bp) that I don’t know how to measure or check if it’s working. Stroboscope is an external unit and works fine on its own.
Thanks for your help
radiator
Re: What component makes a stroboscope flash?
Postby KMoffett » Mon Dec 01, 2014 8:02 pm
How about posting the make and model of the mixer and strobe unit.
Postby radiator » Mon Dec 15, 2014 12:40 pm
Light mixer model: USB9700. Don't know for strobe unit, but i have two of them, both work the same, so the problem is not in the strobe unit.
radiator
$31.24
$6.35
3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3 pictureTO-92 Assortment NPN PNP DIY kit 15 value 600pcs Transistor
$14.40
