Totem pole symbol?
Totem pole symbol?
Postby Solar Granulation » Fri Jan 23, 2015 4:39 pm
Although it's not of dire importance I'd like to illustrate in my schematic that the circuit must be connected to a totem pole pin (such as on an LED driver). Is there a symbol for totem pole outputs?
Solar Granulation
Re: Totem pole symbol?
Postby KMoffett » Sat Jan 24, 2015 4:09 pm
To my knowledge, there isn't a simple single electronic symbol for a totem-pole output circuit.
[url]https://www.google.com/search?q=totem+pole+output+vs+open-collector&sa=X&biw=1288&bih=610&tbm=isch&tbo=u&source=univ&ei=wcLDVI1xjJPIBJiMgvgP&ved=0CEAQsAQ#tbm=isch&q=totem+pole+output[/url]
Postby Solar Granulation » Mon Jan 26, 2015 4:59 pm
In that case, would it be acceptable to create a symbol? I think it would help clarify my schematic, which I do I intend to share with others.
Solar Granulation
Postby KMoffett » Tue Jan 27, 2015 8:56 pm
If I were going to create a symbol for that, I would make a block with a input, the stacked totem pole transistors image as in the attached, an output, and power supply connections as needed.
[url]http://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0CAcQjRw&url=http%3A%2F%2Ftw.renesas.com%2Fsupport%2Ffaqs%2Ffaq_results%2FQ1000000-Q9999999%2Flinear%2Fpw%2Fpw5_009gl.jsp&ei=QPrHVMm5B8P3yQTl4YGIDw&psig=AFQjCNE3S3fRy8KLnWSf09FFEiChtuscHw&ust=1422478219621694[/url]
Silca Flash 008 Key Mill
$499.99
Silca Flash 008 Key Mill pictureC15 6NZ High Hp Flash Files
$79.99
***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge pictureCaterpillar c13 KCB Iva/vva Off Flash Files
Caterpillar c13 KCB Iva/vva Off Flash Files picture
