Need help to select hardware for Audio and BT
Postby ajaygautam1981 » Thu Apr 02, 2015 6:24 pm
I need help to select hardware(minimum memory) which can only support Audio(playback,recording) and BT
Audio - ALSA and Linux, for now it may support mp3 and aac.
Ajay
ajaygautam1981
$27.04
US Stock 154LB 70kg Lifting Magnet Electromagnet Solenoid Lift Holding 59mm 12V picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$375.99
1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves pictureDC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B pictureSDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture
