simple circuit .
simple circuit .
Postby gazi_mostofa_zaman » Fri Apr 24, 2015 6:15 pm
hi i'm jamil..
i'm new here....
I know something about electronics...
now I want to make some circuits
simple circuit...
I want to know what was the 1st circuit you built....
I mean the very 1st....
gazi_mostofa_zaman
Re: simple circuit .
Postby KMoffett » Sat Apr 25, 2015 11:44 am
Battery, light bulb, switch. The switch was an upgrade from a battery and light bulb. Not joking!
$24.99
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureFirst Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New
$449.99
First Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW picture
