Add and subtract mode oscilloscope
Postby TimmyF » Tue May 19, 2015 5:08 am
what waveforms or logic signals would i want to add or subtract when using an oscilloscope?
TimmyF
Re: Add and subtract mode oscilloscope
Postby dscpcb » Sat Sep 12, 2015 8:46 am
Invert mode is used for subtracting two waveforms from the two channels connected to the oscilloscope (Channel A -Channel B).We first invert Channel B and then press the Add mode in the oscilloscope.We can use the same procedure to subtract channel B from channel A.Variable Time base is used whenever we need to fit in a low frequency signal into the screen of the analog o-scope(Remember the screen size is a constant).
dscpcb
$17.92
$40.50
$225.00
$11.06
