Replacing LED bulbs on a small LED Sign
Postby B1gRed » Thu Aug 20, 2015 12:18 am
I have very limited circuit and electrical knowledge. I bought a small "PIZZA" LED display sign from a garage sale. I want to replace the small LED bulbs with 5mm LED bulbs for it to be brighter. I have put in the new LED bulbs in exact the same way but I can only get a section to turn on. Please see attachment for pictures. Please help!
Not enough Power?
zoom in.jpg (1.9 MiB) Viewed 29698 times
Only a section in the middle light up. Double checked all connections.
full after.jpg (1.85 MiB) Viewed 29698 times
How it came and it was working.
full before.jpg (1.52 MiB) Viewed 29698 times
B1gRed
Re: Replacing LED bulbs on a small LED Sign
Postby PradeepKumar » Thu Apr 21, 2016 6:03 am
Might be you need to check with the wiring and its design before you place the new LEDs in the same position.
PradeepKumar
$149.00
$565.00
$799.99
SOLAR ELECTRONICS MODEL 8012-50-R-24-BNC LINE IMPEDANCE STABILIZATION NETWORK pictureTOA ZM-104 Portable Analog Speaker Line Impedance Meter
$198.95
TOA ZM-104 Portable Analog Speaker Line Impedance Meter picture
