AC diode
AC diode
Postby biggusdickus » Mon Nov 16, 2015 6:58 am
Hi New to Electronics.
Is there an AC equivalent to a DC Diode.
I am using 24vac with power from 2 different sources at different times and 18 separate outputs.
Cannot change power to DC via a bridge so power must remain 24 vac.
I have a LED at each power source point to tell which power circuit is on.
Trouble is no matter which circuit is on , both LED's light up.
If I was using DC i could overcome this with a diode at each LED to prevent feedback.
Is there a diode equivalent for AC current?
Current is a max of 100mA.
Appreciate any help offered but please keep the terms simple for a newcomer.
biggusdickus
Re: AC diode
Postby KMoffett » Tue Nov 17, 2015 10:39 pm
I don't think there is an AC equivalent.
Are you saying that you have two 24VAC sources that supply 18 devices, and if one AC supply goes down the other supplies them? But, both 24VAC sources can be on at the same time?
Re: AC diode
Postby rouncer » Fri Nov 27, 2015 6:15 pm
a diode is a diode dude, theres no such thing as an ac diode, generally, if your ac frequency is 60 hz or above its pretty hard to see if its going off and on, cause its cycling 60 times a second, so if you see a tiny shimmering in your leds or even not its probably working fine.
rouncer
Barricade Extreme Flashing Tape - 1 Roll 4In 75 ft Premium
$25.77
Barricade Extreme Flashing Tape - 1 Roll 4In 75 ft Premium pictureC15 6NZ High Hp Flash Files
$79.99
***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge pictureCaterpillar c13 KCB Iva/vva Off Flash Files
Caterpillar c13 KCB Iva/vva Off Flash Files picture
