my own transistor design
Postby rouncer » Thu Dec 03, 2015 1:47 pm
nnp and ppn!! ever heard of that?
they perform not.
..................!signal copy........................
.....................negative...........................
signal..negative..___|___..positive....battery..........
.....................positive..........................
signal..positive...___|___..negative....battery..........
if you team them up, you can make
an amplifier out of batteries.
rouncer
Re: my own transistor design
Postby rouncer » Fri Dec 04, 2015 11:38 am
Ive got my own version of a MOSFET now too.
...........battery.........
signal..-.->.\->...+.signal
the difference is, you use it to change polarity WITHOUT changing the content of it being a 1 or 0.
so i take -1, to be my signal, be it 1 or 0 doesnt matter.
then i add 2 to it. (thats the simplified MOSFET.)
then I do a sneaky trick, do 2 parallel bipolar junctions and make 2 replicas of the opposite of the signal and put it back.
so. -1 -> +1
then 0 -> -2 + 2 -> 0
rouncer
Postby pebe » Sun Dec 06, 2015 11:11 pm
Can any other member make any sense of this stuff, and so justify my not deleting it?
Postby KMoffett » Mon Dec 07, 2015 2:38 pm
pebe,
None of his rambling text, drawings, photos...and especially his videos...make any sense to me either.
Postby pebe » Mon Dec 07, 2015 9:07 pm
Thanks Ken.
I will delete and lock the rest of the thread.
$31.24
$6.35
3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3 pictureMJ15024 To-3 Silicone Audio Power Output Transistor 10 Pack
$39.99
