re: Deleted posts
re: Deleted posts
Postby pebe » Thu Dec 10, 2015 9:42 am
Rouncer,
As you are obviously not reading your Personal Mail, I will repeat mine to you here:
"In spite of my asking you to talk in plain English, you have continued to make postings in the form of aimless ramblings. This is a serious forum and you must realize that if I and at least one other member cannot understand you, then newbies will be put off trying to learn about electronics because they too cannot understand what you write.
Now that you have introduced profanities into your posts and videos, then I am invoking the forum's rules and deleting those posts/threads.
I will continue to monitor your future postings and delete any that break the rules.......
Pebe.
Moderator
$27.04
US Stock 154LB 70kg Lifting Magnet Electromagnet Solenoid Lift Holding 59mm 12V picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$375.99
1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves pictureDC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B pictureMAGNETROL AU-12-100 / AU12100 Electromagnet Control
$215.00
MAGNETROL AU-12-100 / AU12100 Electromagnet Control picture
