Variable voltage and led
Postby Shaam » Sun Mar 06, 2016 5:22 am
I want to mount a circuit which switch on different LEDs at different voltages.
For example, lets say I have 3 LEDS and i want them to light up at the voltages below:
5V, 1st LED
8V, 1st and 2nd LEDs
12V,1st, 2nd and 3rd LEDS.
For varying the voltages, i will be using a 10K potentiometer.
I need a simple circuit with basic components. I will be trying this circuit on a breadboard.
Thanks in advance.
Shaam
Re: Variable voltage and led
Postby pebe » Mon Mar 07, 2016 5:08 pm
It can be done with comparitors. However, to design a circuit you must state exactly what you want - not just 'for example'.
Postby PradeepKumar » Wed May 11, 2016 5:36 am
Comparators is the right option to go with. Just try using that one to see good results.
PradeepKumar
$5.99
$6.47
5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureClarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT
$16.90
Clarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT pictureCavitron power potentiometer for Gen 131, 132, 136, 137
Cavitron power potentiometer for Gen 131, 132, 136, 137 picture
