escalators electric system - control cabinet
Postby barbu.ancuta » Tue Aug 27, 2013 9:30 am
Hi!
I work for a company in Austria and I am looking for creative people that could come up with a solution for the electric and communication system (for an escalator). In case the profile will fit, I can recommend them to the client for a collaboration.
The current electrical control system consists of the drive control system, the communication system and the microcontroller board. All three components are housed in a control cabinet and are connected to several sensors in the escalator. The aim is now to substantially reduce the control and communication systems' weight (currently 50 kg) and dimensions (currently 500x700x300mm), to modernize the entire design and to make sure that the new control and communication system is based on a technology which allows for long-term upgradability and availability.
So basically what they want is a new system design, using standard components, more compact, lighter, easier to upgrade, multi-core system controller and real time, flexible...Has any of you designed similar applications and has great ideas?
Thanks!
Anca
barbu.ancuta
$19.73
150Psi 1/8NPT Stainless Pressure Transducer Sender Sensor For Oil Air Fuel Gas pictureSetra 26410R1WD11A1C Pressure Transducer 24VDC 0 - 0.1" WC 4 - 20mA New
$240.00
Setra 26410R1WD11A1C Pressure Transducer 24VDC 0 - 0.1NOS YORK 025 29583 000 TRANSDUCER 0 - 200 PSI B94
$169.99
NOS YORK  025 29583 000  TRANSDUCER 0 - 200 PSI   B94 pictureSiemens 545-208 Analog Output Pneumatic Transducer
$550.00
Siemens 545-208 Analog Output Pneumatic Transducer picture
