Power supply 220VAC/DC 0-30V/0- 1A: not working ok anymore
Postby Pborsen » Sat Feb 13, 2016 10:44 am
Hi Everyone
I build this power supply in the 80's during my education at an Electronic engineering school.
I designed it to be adjusted from 0 to 30vDC and to adjust the amps limit between 0 and 1 A.
Recently when trying to use it, I can not adjust the tension with the potentiometer anymore. When rotating the potentiometer, it moves from 0V to 30V and can't manage to adjust to another voltage.
I have not run into electronics for years now but can still repair, change circuits,...when I know what to change.
I don't have the diagram any more but can sent pictures of the board.
Any idea where the problem can be?
Thanks in advance.
Pborsen
Re: Power supply 220VAC/DC 0-30V/0- 1A: not working ok anymo
Postby pebe » Sat Feb 13, 2016 5:59 pm
Can't make any suggestions without seeing the circuit, but a photo may be useful.
Postby pebe » Mon Feb 15, 2016 2:31 pm
Pborsen,
If you are trying to upload a photo, please bear with me. There is a fault with the site at the moment that we are trying to get fixed.
pebe, moderator
Postby PradeepKumar » Thu May 26, 2016 6:18 am
Hey kindly post the circuit diagram. Only then it will be helpful to make replies.
PradeepKumar
CH341A EEPROM Flash BIOS USB Programmer Kit with SOP8 Clip
$12.99
CH341A EEPROM Flash BIOS USB Programmer Kit with SOP8 Clip pictureC15 6NZ High Hp Flash Files
$79.99
***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge picturePensky Marten Flash Point Apparatus Petroleum testing Closed cup
$277.38
