PCM design - How to solve this problem?
Postby franky2020 » Wed Apr 06, 2011 1:00 pm
Given an audio signal with spectral components in the frequency band 300 to 3,000 Hz, assume that a sampling rate of 7 kHz will be used to generate a PCM signal. Design an appropriate PCM system as follows:
(a) Design a block diagram of the PCM system, including the transmitter, channel and receiver.
(b) Specify the number of uniform quantization steps needed, assuming that the peak signal-to-noise ratio at the receiver output needs to be at least 30 dB and that polar NRZ signaling is used.
(c) Investigate how nonuniform quantization can be used to improve the performance of the system.
franky2020
Postby pebe » Tue Apr 19, 2011 10:03 am
What is your question?
$49.99
JOHNSON CONTROLS VALVE ACTUATOR  ‎3Nm (27in-lb)  /  VA9203-GGA-2Z pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureJohnson Controls A70HA-2C A70 Series 4-Wire 2-Circuit Temperature Control
Johnson Controls A70HA-2C A70 Series 4-Wire 2-Circuit Temperature Control pictureJohnson Controls P45NCA-12 Lube Oil Protector. New In Box.
$129.00
Johnson Controls P45NCA-12 Lube Oil Protector. New In Box. picture
