Degree project relate to electronic fields
Postby jaden5165 » Mon May 23, 2011 10:46 am
Hi guys,
I'm taking degree in electronic engineering.My project got rejected by my lecturer.Do you guys have any other good project ideas to recommend me?I really need help as the deadline for us to pass up the proposal going to reach.Got genius here can help me.THANK YOU A LOT.TAKE CARE.
jaden5165
Postby rajni » Thu Nov 03, 2011 11:19 am
What is the reason your project got rejected by your lecturer? Second question are you looking for only electrical project ideas?
rajni
$17.92
$40.50
$225.00
$11.06
