calculate effective resistance between node D & node E
Postby nunally13 » Fri Jul 05, 2013 2:44 pm
i have tried to find the effective resistance between node D and node E .. by making (R4+R5+R2)//R6 :D
but i think this is wrong .. do u guys have any other approach to solve this problem.. i wanna know how to find the effective resistance between node D and node E.. :wink:
nunally13
Re: calculate effective resistance between node D & node E
Postby pebe » Fri Jul 05, 2013 5:34 pm
There is no attachment showing the circuit.
Postby nunally13 » Sat Jul 06, 2013 3:18 am
nunally13
Postby pebe » Sat Jul 06, 2013 10:12 am
It's difficult to see your circuit because of the need to scan back and forth. It would have been better if you had used a .gif file instead of a .jpg file, and reduced its size. However,
Let Ra = R2 + R4
Let Rb = Ra and R3 in parallel
Let Rc = R5 + Rb
Effective resistance between D and E = R6 in parallel with Rc
ASCO HV2647003 Solenoid Valve 3/8” 24 VDC (Box 26-063)
$80.00
ASCO HV2647003 Solenoid Valve 3/8” 24 VDC (Box 26-063) pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW pictureNEW 281291 Vickers Solenoid Coil 115V 60Hz OLD INVENTORY
$399.00
NEW 281291 Vickers Solenoid Coil 115V 60Hz OLD INVENTORY  picture
