Handling two different UART device with one port
Postby majidkhalili » Thu Oct 03, 2013 4:05 pm
Hi guys
i dont know if this is the best place ask this , so if i have to post it in different section pls let me know
i have an avr micro controller that is working with PC using one of its serial port , and the avr has only one other serisal port , and i need to work with tow different device using UART , i have know idea what can i do
one of the devices i'm just reading from , and another one i'm bot reading and writing
and the important thing is that for both these devices i have to use the interrupt , so i cant not use just simple mux to handle these to , because they should interrupt the avr to read the value of them , so with mux i migh lose the data
pls tell me any thing that can help
thanks
majidkhalili
Re: Handling two different UART device with one port
Postby pebe » Sat Oct 05, 2013 2:23 pm
As I read your post the communication to the PC is not relevant, but you need to communicate between a single UART on the Arduino and two other serial devices. Is that what you want?
MSA ALTAIR 4X Multigas Detector/Monitor for O2 CO H2S LEL w/ Charger
$99.00
MSA ALTAIR 4X Multigas Detector/Monitor for O2 CO H2S LEL w/ Charger  pictureMSA ALTAIR 4XR Gas Detector Monitor - ALTAIR 4XR
$750.00
$600.00
MSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026 picture
