question need your opinion
Postby kenichi » Tue Oct 29, 2013 4:21 pm
picture A - i think the LED will get burn.
picture B- LED wont get burnt.
question : why picture B wont get burn?
can anyone here help explain?
what will happen if the supply voltage in the picture is 220v is it ok to use 0.1ohm resistor?and what if the resistor is 1Mohm , is it ok to use 0.1v as the supply voltage?
kenichi
Re: question need your opinion
Postby PradeepKumar » Fri Jun 10, 2016 5:53 am
Picture B is slow because resistors limit the current flowing through the LED.
PradeepKumar
Postby Relayer » Thu Jun 30, 2016 3:25 am
PradeepKumar, why are you answering old posts like this one?
It being 3 years old, do you really expect a reply, let alone the op coming back to the Forum to see if someone has replied?
Also, did you bother reading the rest of his post? Wanting to connect 220V to the circuit? This would be a safety issue and if you had any knowledge you would have warned him not to even contemplate using 220 volts, which I'm certain would be AC.
Sorry mate, but please DON'T answer posts which you're really not sure on, you're only making yourself look like an idiot. :roll:
Relayer
Postby KMoffett » Thu Jun 30, 2016 2:43 pm
Relayer,
Since PradeepKumar joined the forum there is a habit of doing this. If you look at his(?) previous posts, they are mostly replying to old, old posts
$13.49
Long-Lasting 4oz Dielectric Grease for Electrical Connectors - USA Made Quality pictureSalisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel
$130.00
Salisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel pictureLineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read Lot L
$54.95
Lineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read  Lot L pictureRFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114
$249.99
RFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114 picture
