photodiode boost
photodiode boost
Postby jack mcleod » Tue Apr 12, 2011 4:29 am
The photodiode (glued over a red indicator LED) outputs 1 micro A &
4.8 mV when the indicator LED is activated. A 2nd. red LED needs to duplicate the indicator LED' action. Need a circuit to drive the 2nd. LED.
Supply 12V, 471 op, 2N2222 and 2N3819 Fet handy any thing is good.
jack mcleod
$7.77
$400.00
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 pictureAutomated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller
Automated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller picture
