Converter
Converter
Postby EAUX » Sun Jul 31, 2011 2:12 pm
how would u modify this circuit with minimum components to give 0 to -22vdc output @ IO2 by the actuation of s1?
Thanks in advance.
[img]http://i452.photobucket.com/albums/qq242/erickejah/challengedesign1.png[/img]
EAUX
Postby pebe » Tue Aug 02, 2011 10:45 am
Have you got your circuit right? because you have the emitter of the 2N2222 going to a symbol 'VCC'.
When SI is at the 'ground' position the transistor is already in conduction and saturated, and switching an extra 5V to point 101 will provide even more base current. So there is no way you can get the transistor to switch on and off with that circuit.
One way would be to connect point 101 to ground and connect S1 between the base and emitter of the transistor.
Pyle PTA44BT 4-Ch Bluetooth Audio Source Amplifier 500W Home Theatre Receiver
$79.99
Pyle PTA44BT 4-Ch Bluetooth Audio Source Amplifier 500W Home Theatre Receiver pictureSKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER
$137.49
SKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER pictureUSED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER
$104.99
USED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER pictureAvon VPU Audio Amplifier 71009/2 for Avon FM50 / C50 Respirator Gas Masks
$110.00
Avon VPU Audio Amplifier 71009/2 for Avon FM50 / C50 Respirator Gas Masks picture
