measuring current
measuring current
Postby kripzzz » Fri Jan 06, 2012 7:13 pm
i need an IC to sense current of range 0-8 micro ampere of resolution 9 nano ampere.. it is then required to measure that current..
kripzzz
Re: measuring current
Postby Thomas W » Sun Jan 08, 2012 3:36 pm
Is there sense resistor in the circuit you want to measure on? Or how are you going to interface to the circuit under test?
Thomas W
Postby kripzzz » Sun Jan 08, 2012 5:36 pm
[quote="Thomas W"]Is there sense resistor in the circuit you want to measure on? Or how are you going to interface to the circuit under test?[/quote]
i'm going interface using an I2C.. actually i'm not sure if to use a current sensor or anything else..
kripzzz
Postby Thomas W » Sun Jan 08, 2012 9:24 pm
I'm thinking an opamp with high input impedance, with the output connected to an A/D converter with I2C interface.
What kind of circuit or component do you want to measure the current in?
Thomas W
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureOEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690
$94.55
OEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690 pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style pictureDayton 4Z527 Dc Speed Control, Scr, Enclosed, Nema 1, 2A Max Current, 0 To
$150.99
Dayton 4Z527 Dc Speed Control, Scr, Enclosed, Nema 1, 2A Max Current, 0 To picture
