Voltage Limiter help!
Postby DJ Higgumz » Sat Mar 10, 2012 3:15 am
building a sub box for a friend, and i want to limit output from the amp to 19 volts. don't get on me about miscalculation of volts, this sub is very efficient, at like 110db per 1 watt, that is the correct voltage :) . anyways what I want to achieve is to have something to limit the voltage once it gets to that point. even if it is a led that turns on at 19 volts that would work. simplicity and affordability are key! new user so be nice :D
DJ Higgumz
Vintage Transistor & More Lot 190 Pcs. Gold Leads Motorola Fairchild Philco
$125.00
Vintage Transistor & More Lot 190 Pcs. Gold Leads Motorola Fairchild Philco picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
$54.99
$6.35
3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3 picture840 PCS PNP NPN Power Transistor Assortment Kit 24 Types Electronic Component
$24.48
840 PCS PNP NPN Power Transistor Assortment Kit 24 Types Electronic Component picture
