FM radio with LCD screen
Postby Tonko » Tue Feb 28, 2012 12:30 am
Hello, I'm wondering if anyone knows of a DIY electronic kit for an FM receiver that has an LCD screen to see the frequency you are on. Obviously there are plenty around that use dials, and lots of cheap radios use a 'scan' button. But I want to be able to see the frequency and lock it there...
Alternatively if there is a way to add an LCD screen to a scan radio, that may help, but something tells me that would require a chip and programming...
Any help or info would be greatly appreciated.
Tonko
Re: FM radio with LCD screen
Postby Major_Problem » Wed Apr 18, 2012 11:43 am
There are lots of small transistor radio's that already have such a display. It is a lot cheaper to get an `of the shelf version` than to build it your self. This needs a radion, display drivers, frequency counters an an LCD screen. When you want to measure the frequency you are on, you need to measure the VCO-frequency and add the frequency-delta between VCO and input frequency.
So a lot of stuff and effort to display the frequency you are on. Take a look at dealextreme, they ship it for free...
Greetz,
Wim
Major_Problem
Postby Major_Problem » Wed Apr 18, 2012 11:48 am
Found it: Only $17.60.
sku_50731_1 radio.jpg (25.57 KiB) Viewed 6678 times
Major_Problem
Postby Major_Problem » Wed Apr 18, 2012 11:59 am
But if you don't want to use a scan button, try a car-radio. They ar available for around 40 dollars.
Greez,
Wim
Major_Problem
$14.98
6Pack K Type Mini-Connector Thermocouple Temperature Probe Sensor Cable pictureThermocouple Thermometer Temperature Data Logger 4-Channel K/J/T Type Thermom...
$112.38
Thermocouple Thermometer Temperature Data Logger 4-Channel K/J/T Type Thermom... picture351302170065 Thermocouple Heavy Duty - 72 Inch -
$50.00
351302170065 Thermocouple Heavy Duty - 72 Inch -  pictureCooking Performance Group Thermocouple 351302170058
$45.50
Cooking Performance Group Thermocouple 351302170058 picture
