Confused about how to plug in these blue and white wire cabl
Postby spokken2 » Tue May 01, 2012 9:34 pm
Confused about how to plug in these blue and black wire cables for my new speakers? @_@?
So I just got these new speakers and was insanely hype about them, I have the basic things set up correctly but now I'm wondering how am I suppose to work with these blue and white cables. Only one speaker is working so im guessing that the second has to be connected with the cables. But where or how do I place them??? :/
http://i417.photobucket.com/albums/pp25 ... eakers.jpg
spokken2
Re: Confused about how to plug in these blue and white wire
Postby I_Daniel » Thu May 03, 2012 6:19 am
The white wire after viewing the image is the Positive (+) lead and the blue the negative (-) lead.
[b]How are the connections labelled on the speakers ?[/b] I have found some speakers to have RCA connections, others miniature telephone-jacks, some have screw connections marked + and - and others have small pressfits. that is you have to press down or up to open the connection point, insert the lead and then release it and they are mostly Red for positive and Black for negative. So please say regarding the speakers and amplifier , which one is yours ?
$27.00
$469.95
$299.99
